According to "Ball & Roller Bearings, Theory Design & Application" Brandlein et Al, (basically FAG), the index of static stressing is defined to be:
fs = Co/Po
where Co = Basic Static Load Rating
Po = Equivalent Static Bearing Load
The value of Co is computed based on the total rolling element and raceway deformation equaling .01% of the rolling element diameter on the most heavily loaded rolling element. This is a somewhat arbitrary criterion, and as will be seen below, it may often be exceeded without disastrous consequences.
The above reference quotes the following acceptable values for fs, the logic of which I do not profess to fully comprehend :
Occasional rotation : fs = 1
Less deformation acceptable (50% of standard) : fs = 1.5
Larger slewing, no shock : fs = 0.6 balls, 0.7 rollers
Shock loads or small oscillation angles : fs = 0.7 balls, 0.75 rollers
Spherical roller thrusts : fs = 4 (because of unfavorable lip loading)
I don't know if this is what you are after. I have frequently used safety factors of 2 or 3, because the real loading conditions are often unknown. It all depends on how accurately you can predict the loading. Of course, bear in mind that with static load ratings, if you only exceed the rating one time - you will permanently brinell the bearing some definite amount. On the other hand, nothing noticeable will necessarily occur immediately – possibly just some extra noise.
