Hi all,
I need to calculate the bearing capacity of a spread footing.
B= 2 ft.
L= 19 ft.
Df= 1 ft.
The underlying soil is mainly stiff clay.
The bearing capacity, using Terzaghi's theory, is kinda low. I can recommend using a geosynthetic as reinforcement, after replacing 0.7 ft. with granular soil.
What theory should I use for this calculation?
Das (1988), Patra et al (2005) or Omar (1993). The first one uses Geotextile, while the second and third use Geogrid.
I want to make sure I do the right thing. Do you have any recommendations to make: Geotextiles or geogrids? Or any other methods?
B= 2 ft.
L= 19 ft.
Df= 1 ft.
