mfstructural
- Feb 1, 2009
- 230
I am designed a steel canopy that is 60' long and 24' wide. The canopy will be up against an existing CMU building. The CMU is 12" and the 60' long section will be up against the building. I'm planning on 4 columns spaced at 20'. Wanted to get people's preferred method of attaching steel beams to an existing CMU wall. I'm contemplating knocking out part of CMU and bearing on a grouted stud plate, or through bolting (bearing on CMU) or anchoring to face of CMU. The reinforcing/grouting pattern of the existing wall is unknown so there would have to be a note on drawings to verify if cells are grouted. Do you typically add a note to verify that reinforcing is also installed in the cell at beam bearing? I feel that it is hard to coordinate that and if there isn't a bar not really feasibly to add one.
One issue I have with this canopy is that a steel WF beam is bearing on the CMU at the interior within a foot of where a canopy beam is located. The reaction from the existing beam is 24kips and the reaction from the new canopy beam is about 10kips. I want to avoid knocking out any CMU or bearing near this existing beam but wanted to be people's thoughts. I can provide some photos if needed. There is also a height issue that might dictate the beams be mounted higher which could interfere were steel bar joists located adjacent and parallel to the subject wall.
I'm debating on adding 4 columns against the existing CMU wall with isolated ftgs doweled into existing foundation. This will avoid adding load near the existing beam and also any potential interferences with the bar joists. The columns can be attached to the CMU with angles for lateral stability. or a ledger along top of canopy to attached to.
