battery pack construction
mccdeuce
Marine/Ocean
I am working on a project that requires a very small battery pack. The requirement is for a 200mAh 9-14 volt battery, that is as small as possible.
My thoughts are to put 3 3.7 volt 200mAh cells in series. The cells will be encased and I will need to setup a simple method to charge the cells as well.
I am not an Electrical Engineer but have done some EE work. I have looked at a couple of different comericial options to fill the need, but have not been happy with most. Any advice is greatly appreciated.
Try Valence in Texas for the most energy per volume and the processors to achieve level charging.
