Batch print and export
TimHat
GB
Does anyone know a good way to...
1) Batch print solidworks drawings
2) Batch export from SolidWorks to eDrawings
For example, say I have a directory full of solidworks files, is there a way to batch print and export those? Alternatively, say I have a load of files open inside SolidWorks, is there a way to batch print and export?
Cheers, Tim
Which version of SW do you have?
The SolidWorks Task Scheduler is included with the Professional and Premium versions.
[cheers]
Thanks for all the responses guys. We have SW Premium 2007 but I've never come across Task Scheduler. I'll have a look.
Tim
The problem with any automatic method is that none (so far) account for differences in printer settings between drawings. If you save a PDF, it changes the print settings and will print as garbage on a physical printer if you are tring to print to fit or have a different paper size.
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
