buckman1122
Chemical
I have an application that requires cooling 2700 gallons of whey from 132° F to 85° F in 20 minutes using a double tube heat exchanger. The problem I am encountering is the fact that my customer is only pumping at 75 gpm through the heater and this results in only 1500 gallons of the whey passing through the HX (after 20 minutes).
I need to know how to calculate the temperature at which the fluid exiting the HX should be so that the remaining 1200 gallons of 132° F whey will achieve the 85° F required. Obviously this is a transient heat transfer problem but I'm having difficulties finding a good model to perform the calculations with.
