basic problem involving Internal energy and entropy of a vessel 1
tech2580
Petroleum
Sep 9, 2010
1
The problem is:
A 2ft^3 vessel is filled w/ 1 lbm of water at 100psia. What is the total internal energy and entropy of the vessel?
It's been a while since working a problem like this, any ideas?
Everything is greatly appreciated, many thanks in advance
you need any 2 properties to determine the other properties.
You have P= 100psia, and v= 2./1. = 2 ft3/lbm.
so now use a steam table and obtain the rest.
Since 0.5 lb/cf is not the density of the water at 100 psia, can you tell us the temperature?
From the tables I’ve got at p = 100 psia and T = 327.87 °F the specific volume of steam v = 4.43313 ft3/lb.
My steam tables didn't show a value for the given data. Therefore I had to assume it is a mixture of liquid and vapor.
It appears to be wet steam with a 44.9% quality as shown by the "calculator" suggested by davefitz.
25362,
I was referring to dry steam. I agree with you that wet steam (44.9% dryness) has the values of enthalpy reported by davefitz
At the given pressure and specific volume it cannot be "dry steam". It is a "saturated mixture"
One exception to the statement:
You need any 2 properties to determine the other properties.
It cannot apply when the two given properties are saturation pressure and temperature. In this case one needs an extensive property.
Or specific volume, which is another intensive property.
