Basic Lofting
  • Thread starter Thread starter cecil699
  • Start date Start date
C
cecil699
Guest
I need some help with lofting...Is it similar to Pro/E where you have to assign a tragectory first? Or, draw the final shape. Any help would be great.
Thanks, Jay
Jay:
It has been a while since I used Pro-E, however, when using the lofting command, a starting profile and finish profile are used. Intermediate profiles can also be employed. These profiles must be selected in the sequence to generate the loft. You can also use a begining and ending profile and provide a centerline (trajectory path) to direct the loft.
Now a sweep can be used with a starting profile and a trajectory path to control the solid created.
He this helps
Bryan
