transmissiontowers
Sorry for the dumb question but I mostly do frame and truss analysis and only do FEA very occasionally. I use GTStrudl and their baseplate wizard to model and mesh up a flat plate with an angle welded to it held down on anchor bolts.
By hand I usually find the bolt loads and pick a bend line and sum moments about it to design how thick to make the plate by finding the stress at the top or bottom of the plate.
When I run the FEA and mesh up the plate and apply a load to the angle, I get results and I can see very large stresses at the tips of the angle and the stiffeners welded to it. The stress drops off quickly.
So my question is, do I make the plate so thick that there are no stresses above yield at any point in the mesh (even at the stress concentrations)? This is very conservative, but logic tells me that the plate will not fail just because a few nodes are twice the allowable yield stress.
I can assume a bend line through the point with the high stress and if I calculate the resultant forces on this cut, I can make the bend plane long enough (I usually assume 12 times the thickness as a limit) so that the P/A + M/S is below yield.
I'm thinking for the plate to fail in the real world, it will have to get plastic across the thickness so the plate tears.
My loads are due to hurricane wind so they are short in duration.
How do you FEA experts size the base plate thickness?
_____________________________________
I have been called "A storehouse of worthless information" many times.
