Ganesh Persaud
- Nov 21, 2018
- 94
Hello Everyone,
Firstly, is this correct, when bolt configuration of a base late is inside the flanges of the column, it's considered to be pinned, and if the bolts are placed outside of column flanges, it's considered to be a fixed connection?
Secondly, in general, I noticed that pinned base plates has smaller beam sections rather than a fixed base plate connection. Can someone explain this?
Thirdly, Can someone refer me to aisc calculated example as it pertains to a stiffened base plate design. Is it a case where it is designed like a normal baseplate checking breakout and pullout, etc with additional checks to see if it require stiffener plates.
Thank you
Thank you
