Ok, I have always been told that for base plates supporting a moment frame, you design the base plate for just axial load and not for moment even if it is part of a moment frame. The idea is that it frame will develop a hinge near the base plate but not at the base plate. If that is the case, do you typically bolt within in the interior depth of the column or do you bolt on the outside the column depth? This is a question in reference to building design and I just asking for your opinion.
The resisant virtues of the structure that we seek depend on their form; it is through their form that they are stable, not because of an awkward accumulation of material. There is nothing more noble and elegant from an intellectual viewpoint than this: to resist through form. Eladio Dieste
