I have two piston cylinders one of which will contain hydrazine (N2H4) and the other nitrogen tetroxide. Both pistons will be pressurized to 1500 psia and need to have a high precision bore. Currently I am looking at coating the cylinders with Xylan 1010 which to my understanding is a resin bonded fluoropolymer with a variety of other additives such as PTFE. A Whitford rep told me he was unsure if the coating would react, but was fairly confident that the coating would work as long as the base material was resistant as well.
I was thinking of using stainless steel 304 or 316 for the base, but have not found enough information on how stainless will react with the two chemicals to feel confident in using it.
I don't have much experience with this type of material selection and don't have a strong background in chemistry so any information or opinions on the coating or base material selection would be appreciated.
