I have a 2.5 inch space above my board for a whip type antenna. I am at 315 MHz, so that is too short for a quarterwave. I found some helical wound berylium copper, trimmed it to 2.5", and it resonated down at 250 MHz. I screwed around with base loading the antenna with a series capacitance, but was unable to tune it much higher than 273 MHz.
So, what am I doint wrong. IF the length was too short, I could electrically lengthen it witha series (base load) inductor. So why, if the length is too long, can I not do the same thing with a capacitor?
I could just trim the helical length shorter until it resonated at 315 MHz, but I assumed that the longer length, properly resonated for center frequency, would give me a more efficient antenna.
