Flounder56
I am working on a sprinkler design for several warehouse/commercial buildings with Open Web Steel Joists.
Trying to located my sprinklers as to prevent obstructions to the sprinklers due to the Joists. The sizes of the OWSJ have not been determined.
What are some typical sizes that are used? I pulled out my AISC Steel Construction Manual and sizes for the double angles can range from 2"x 2" to 8" by 8". I don't work in this field so any input would be appreciated.
I typically have only seen 2"x 2" double angles used. Are other sizes typically used, or reasons why I haven't seen the other sizes?
Also the joist depths are typically 30" to 36", would it be a safe assumption to assume that a typically joist depth would fall into this range?
Thanks.
Thanks.
