Balloon problem with a subassembly
mncad
Industrial
Running SW2005 SP3 I'm having a problem with adding balloons in a drawing. I have a subassembly that some of the items show an "*" instead of the item number. Some of the parts of the subassembly balloon just fine but others show the asterisk. If I put the subassembly into its own drawing all of the parts balloons just fine. Am I missing a setting or something? I'm using the SW BOM and I have it set to show parts only. Any suggestions?
Thanks,
mncad
Do you get the same result when you use the Auto-balloon?
[cheers]
Making the best use of this Forum. faq559-716
How to get answers to your SW questions. faq559-1091
Helpful SW websites every user should be aware of. faq559-520
Open your assembly, go to the part in question. It should
say (Excluded from BOM) after the name.
Right click- select Properties, and uncheck "exclude from
Bill of material"
I get the same result when use the auto balloon.
mncad
BOBcaddesign,
I have been thru all of that, none of the parts are excluded from BOM. And the subassembly balloons just fine when I put it into its own drawing.
mncad
Do you have 2 subassemblies and trying to attach balloons to all of the parts?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ559-1100
FAQ559-716
Correct, there are a few parts and a couple of subassemblies within the top assembly and I'm trying to balloon all of them.
mncad
The assembly you are working on with it's own dwg, add 1 balloon to each subassy and 1 balloon to each part added to the subassy. Do not add balloons to parts within subassemblies. Each subassy gets it's own dwg with balloons.
Chris
ctopher's home site
FAQ559-1100
FAQ559-716
ctopher,
This is a drawing going to the customer to show them what they are purchasing and how it fits together as a complete unit, I need to be able to balloon everything in a single drawing.
mncad
Either build complete assy without subassemblies, or add balloons and type item numbers manual which will not update in BOM automatically. You will have to update BOM manually.
Chris
ctopher's home site
FAQ559-1100
FAQ559-716
Right-click on your BOM and select Properties.
Next for your BOM Type select Parts only.
This will list all parts in the assembly including sub-assemblies and their parts. You should be able to balloon each item after you have done this.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP3.0
