Hi all, I've got a bit of a challenge for you (I think).
We need to melt a large tote (big plastic cube) full of wax. A heat wrap blanket was purchased to accomplish this, but the results were not acceptable. The heating blanket took 5 days to melt the wax, when ideally, we'd like to have it melted in 24 hours.
Here are the vitals:
Volume of tote: 47.2" x 39.4" x 45.7" (1.39 Cubic Meters)
Weight of wax: 83 KG
Heat of Fusion (melting) for Wax: 34 Calories / Gram
Melting Temp of Wax: 27 to 32 degrees C
Specific Heat of Wax: 2.1 KJ/(KG*Kelvin) (@ 20 degrees C)
Moloar Mass: 720 to 780 g/mol
Heating Blanket:
Wattage: 1440W @ 120VAC
Max Temp: 71 degrees C
Time taken to melt the tote of wax: 5 days
The tote has a large metal cage attached to it, so the hot blanket is not in direct contact with the tote.
It is proposed to replace the heating blanket with a hot box (essentially a large oven). This oven would heat 2 totes at once. Here are it's vitals:
Wattage: 9000W
Max Temp: 135 degrees C, plus a circulating fan to imporve convection.
Here's the question:
Can you prove, using appropriate formulas, that the hot box will in fact melt the wax faster than the heating blanket (preferably in ~24 hours).
Thanks in advance,
Adam
Heating Blanket:
Wattage: 9000W
Thanks in advance,
Adam
