I have got a plethora of questions regarding these valves. Can the forum members enlighten me
(1) For what type of applications and fluid media these types of NRV for more suitable?
(2) Is it preferable to use a ball check than a piston check for the fact that piston check relies on spring force for closure and may loose its resiliency in course of time?
(3) Is it true that a ball check will experience less erosion than a piston check due to the fact that ball check has almost a point contact to its seat when used in a dust-laden gas or corrosive liquid media?
(4) Does either type work equally well in vertical and horizontal orientation? For gaseous and liquid media?
(5) Do they have any specific advantage over swing check valve or pinch valve?
(6) Does ball check give tighter seal than piston check?
(7) Is dP normally higher for a piston check than a ball check valve?
(8) Please tell me any other prominent features / advantages of these two types of check valves that I haven't mentioned above.
Cheers,
Amin
Cheers,
Amin
