What loadings should I use for calculating the timbers required for a balcony?
I appreciate the normal loading is 1.5kN/m2 plus ceiling & deck load of about 0.4kN/m2 but do I need to include a snow loading or is this only required for roofs rated for "access for maintainance purposes only" with the lighter 0.75kN/m2 requirement?
I am about to re-surface a balcony using fibreglass which has 4"x2" timbers over a 2.4m span with a 300mm spacing which I calculate is okay provided no/little snow load is required. Seemed a bit light to me but if it's sufficient I don't want to replace it & the ceiling if I can help it.
On another timber component, I am considering the use of a "flitched" beam rather than a built up beam. Is the steel required for this ordinary mild steel or is it structural steel?
There is currently a long span double beam which has some rot & may be a bit small depending on whether I need to account for snow so I shall be replacing it.
TIA
JJ
TIA
JJ
