Balancing service?
NHPilot
38
Anyone know where I could get a 12.75" dia. X .09" thick disk dynamically balanced up to 6000 rpm? The disk has a thru slot and a set of 'counter balance holes' opposite the slot but on a different 'bolt circle. All holes are through. The cad system shows that the theoretical center of mass and center of rotation are the same. Taking into account machining tolerances and consistant material density, I need a backup plan should these disk's (there are 3) need balancing. Two counter rotate on a common 6mm shaft 1/8" apart although I would prefer to balance the disks separately.
Pilot, try a local electric motor rebuilder. I had a pulley done at my local one a few years ago and they did a nice job. Be forewarned, you may have to make a mandrel, as I believe they usually just balance the rotors on centers.
NHPilot,
What you are asking for could be hard to do. A dynamic balance involves 2 or more correction planes ........ with 0.090" plane seperation, this is a tall order. Also, un balance does increase as a square of the speed, but at 6,000 RPM your part mounted on an arbor may become flexiable, (depending on balance machine bearing span, and other factors),not to mention mounting concerns with the loads that go along with that speed. At any rate, I do know of a place, if you are still looking, you can email me
rrasdave
How are these going to be mounted? The "wobble" is going to determine just how much "dynamic" unbalance you will see. If that will not be consistant then a dynamic balance will be a waste of time. At 6000 RPM they may well flex differently than when run in a balance machine.
Good luck
Ralph
Given the thickness of these discs, an accurate static balance may be all you need.
We can do it on our Static Hoffman , or you can go to Balco.com, and let them help you, they do work from steam turbins down in size
The suggestion of going to an electric motor shop is pretty good. Another one that I've used is the guys that do racecar engines--if it's in the size range of automotive flywheels and crankshafts they can sometimes do it.
Of course, CAN and WILL are different things.
