I am developing a spreadsheet for analysis/design of foundations for vibrating and rotating equipment. This post is about input for that design, specifically the eccentricity
of the rotor(s) in a turbine generator. It also should be applicable to other types of rotors as well. I am concerning myself right now with rigid rotors, not flexible rotors.
The textbooks I have available do not give much information about the eccentricity of the rotor as input. The made-up examples merely state the eccentricity resulting from a
static balance, and demonstrate how to use that value. That value is for a flexible rotor, and is not my concern here.
I have a real-world example from an upcoming project. I have in hand a proposal from a vendor which gives incomplete data, so at this point I will have to make some
assumptions to proceed.
The data I have is as follows:
W rotor turbine = Later (I will assume W rotor turbine = 50 k, because I need a value)
W rotor generator = Later (I will assume W rotor generator = 30 k, because I need a value)
c.g. location along rotor length = not provided (I will ask for this, for now I will assume that cg is mid-length of rotor for each rotor)
operating speed = 3600 rpm
normal operating speed range = not given
maximum overspeed = not given
Rotors are balanced to ISO 1940 Grade G2.5.
I have calculated the eccentricity of the rotor mass in two different ways. First using Eq. 6 from the ISO standard. I go through a calculation that includes a parameter U
per, and from there, I calculate the eccentricity of the rotor mass in mm or inches. A second method is to start with the operating speed of the rotation in mm/sec (for a
Grade G2.5 balance, this is 2.5 mm/sec, per the ISO standard), and divide by the operating frequency in rad/sec, and get a value of the eccentricity in mm / rad, which is the
same as mm. Both calculations give the same result. Please see the attached spreadsheet on the tab iso1940. Look in rows 18-41.
ISO 1940 applies to rigid rotors only.
It isncludes a definition of rigid rotors: that the unbalance does not change within the speed range, and that the position of all the mass elements of the rotor relative to
each other remains sufficiently constant within the speed range. I have read essentially the same definition of a rigid rotor in Haris' Shock & Vibration Handbook 5th Edition
in Chapter 39 Part 1. I have also read other definitnions of rigid rotors in other articles, such as: rigid rotor is one that operates below the critical speed; or that a
rigid rotor is one that operates at 70-75% of critical speed.
It seems to me that if for a rigid rotor, if the eccentricity does not vary significantly with rotor speed, then it really does not have a critical speed. So neither of the
latter definitions make sense.
I also have found that the eccentricity of a rotor balanced to, say, G2.5 varies greatly from zero to about 1000 rpm, above that the eccentricity is almost constant. Refer to
the graphs of the eccentricity in my spreadsheet, one on log-log plot, and the other plot of the same data on semi-log plot. I also noted that the size (weight) of the rotor
has no effect on this eccentricity. All rotors balanced to G2.5 have the exact same eccentricty and any speed, regardless of the weight.
Based on the definitino of the rigid rotor given in ISO 1940, the plot of the eccentricity does not have one, two or three peaks corresponding to critical speeds, because it
does not "flex" like a flexible rotor does. In other words, the radial centrifugal force due to the rotating eccentric mass does not cause any lateral deflection of the shaft,
so the resonance does not happen.
I have no idea if hte balancing process done to the limits in ISO 1940 is a static balance or a dynamic balance, but I don't think this is an important distinction for what I
am trying to measure and input into my foundation design spreadsheet.
I don't know if the unbalance I've calculated is to be applied to one or to more than one plane. I don't know if it should be applied to one or more tolerance planes or to
balance planes. I don't know if either if these is significant for my goal or not.
So, now to my questions:
1) Which of the several definitions for a rigid rotor is correct?
2) It seems to me that the weight of the rotor ought to affect the eccentricity of a balanced rotor, but my calculations do not indicate that. Can someone exlain this to me?
3) Does a rigid rotor have critical frequencies?
4) Are either of my calculations for eccentricity of the rotor mass (weight) at the operating speed correct?
5) Please see my attached spreadsheet, on tabs Rotating - critical speed (e dyn in cells I40-J40 and I50-J50) and rotating limited input (e dyn in cells AT121-AU121 and
AT129-AU129) for examples of what I will do with the rotor eccentricity once I have it. (Please note, in the first tab, that is a calculation for a flexible rotor, I have to
modify that slightly for a rigid rotor.) Is my application of the results from the ISO 1940 balancing an appropriate one, or is the nature of the unbalance something
different entirely from what I am trying to use it for?
I hope that someone can shed some light on this subject for me. My thanks in advance for any insight that may be offered.
chichuck
chichuck
