Walterke
Industrial
- Jun 22, 2011
- 451
(Using nx nastran on siemens NX 7.5)
Sometimes when I'm performing a simulation on a file, when the calculation is complete it gives me the error 'no results are found'. In 99% of the cases, changing the parameter bailout to '-1' will fix the problem and the result will show me what I did wrong (usually, there are too many degrees of freedom because a part is not connected properly or things like that)
My question is: What exactly is the difference between calculating with bailout 0 and bailout -1? What exactly is being calculated when bailout is on 0 and it won't give me any results?
This question probably comes from lack of knowledge of the subject but I'm hoping someone here can explain this to me.
Thanks in advance.
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
Thanks in advance.
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
