Bad Bridge Bearing Design Details 3
STrctPono
I need your guys' help in finding issues with these details. See attached. I have not been around long enough to have seen this design implemented in older concrete bridges or to see how it has performed. From what I hear from the older Engineers, corrosion, maintenance, and replacement have made this bearing type obsolete.
I have a list of issues and want to see if you guys have any more concerns.
 https://files.engineering.com/getfile.aspx?folder=168b23c9-d9a2-4f67-acc1-4d3b6068e136&file=Untitled.png
Thanks for the link.
Anode.... Check
Cathode..... Check
Return current path..... Check
Electrolyte...... Check
Moisture..... Check
no problem. When the file upload is fixed I'll post the article.
bb,
Did you have problem to upload files to E-T? Quite a few people have the same problem, me included.
retired13 - I'm unable to upload files or pictures. I emailed the management and they said they're looking into it.
bb,
Thanks for confirmation. JoshPlum explained how he solved the problem at near the bottom of this thread Link. I might try it later.
