I am trying to find a way to switch between boards connected to a backplane.
Here's what I'm trying to do:
I am automating the test for a certain board that is attached across a backplane to a CPU board. Because of the simplicity of the test, I'd like to be able to attach multiple boards to the backplane at once, but be able to switch between them. Each board has a fifty-pin connector that plugs in to the backplane.
Is this possible? I realize I could use 50 latching relays per connector, but they take up quite a bit of real estate and at 3+ dollars apiece it gets rather expensive. Is there a better way to switch all fifty signals?
Thanks for any advice!!
