neither the name of the used template nor the sheet's size
(i.e 'A2' or 'D') are available without doing some programming
hereby assuming your posting refers to a draft. The only thing
you can do is to add the location or the name of the template
manually to a custom variable within your template(s).
Same applies to the sheet size: add it as a textbox to each
background sheet .
dy
