background color
  • Thread starter Thread starter write2bush
  • Start date Start date
W
write2bush
Guest
Hello, friends
Is it possible to change the background color to black in the drawing mode?
Thankyou all in advance.
hi
u can change the background color by going to options tab-drafting-general-sheet background-and select ur color.
bill
hi
you con change the sheet background and detail background color by in options-drafting-general-colors-chooseur sheet background and detail background color .
majid
and can i change the background colout in feature creation mode.
Yes you can, go to View> Display Settings> System colors
Hi, Friends,
I Found the tab-drafting-general-sheet background color, I selected the desired colorfor both detail background and sheet background, there is no change
Am i missing some thing? I am desporate, I think i am going to go blind in a few days
Hi
Don't worry!
These options apply to drawings created with versions prior to V5R14. For drawings created with V5R14 onwards, sheet and detail backgrounds colors are defined in the standard file, under the node<KBD>SHEET colors</KBD> of<KBD>GENERAL</KBD> node.
