Back to back ball bearing arrangement
newby81
CA
I have a simple wheel to which I would like to fit 6205-2RSH bearings. The wheel hub diameter does not allow for a larger bearing OD. This bearings does not have the load capacity I need but the wheel hub is 3.5" long. My thought is to fit 4 of these bearings (2 paired on each side).
I feel I should have a thin bearing spacer between each bearing pair but strictly speaking, is this really necessary? Can the bearings simply be pressed in the the wheel up against one another?
It's common to put two bearings in a housing without spacers. The clearance in the bearing allows the inner races to butt without preloading the bearing. I can't tell you if 4 will work. You will need to compare the clearances with the total displacement required to butt the 4 bearings together.
Have you considered cylindrical roller bearings for this application?
I would consider using angular contact ball bearings that actually can be stacked 'back to back'.
Stacking deep groove ball bearings should work for a pair (think rollerblade wheel) but adding a third or fourth bearing probably won't help at all.
The load is over 8000 lbs ? What is a 25 mm axle going to think of that ?
A nice pair of tapered roll bearings might be worth considering.
Note a rotating hub and stationary shaft require the bearing ODs be ≈.001" Ø interference fit.
A snug slip fit on the axle is OK, and pretty much a requirement to set the bearing clearance.
Ref automotive front wheel bearings for most of the recently expired millenium.
