I'm new here in this forum, and i find it amazing
I'm working on a bench test for testing check valves. I found some examples of this test where a back pressure is used at the outlet ( to the tank). I don't really understand what a back pressure valve does. Does it help maintain the pressure in a system? for example, if i connect my pump to it directly ( pump-> Back PV=> Tank), Would it help to rise the pressure in order for the circuit to function?
What are some of its characteristic that i need to design one.
Thank you for your time and help.
