Probably a pretty simple question for you guys. A supplier designing and installing a low pressure (3barg) steam line for a refinery plant has specified schedule 10 pipe work. The extent of their design currently is that schedule 10 is pressure rated > 3barg, with no calcs in alignment with any code. The demand is as high as 1500kg/hr, and thus to obtain acceptable operating velocities the line size is DN100. We have had a number of issues with this supplier, namely poor understanding of local engineering standards in New Zealand where this project is being complete (they are Malasyia based where standards are typically lower I presume). This and a number of other issues causes me to question their capabilities in some errors. Effectively we follow AS4041, which mirrors ASME B31. I have instructed them to prepare design documentation in accordance with this for us to review, but prior to this I want to check something: Under this code, the pipe will certainly come under hazard class E. I have never though in my short career seen steam and condensate pipe work be installed in schedule 10, even at lower pressures. Alas, a code is a code, what is the industry standard out there and what might you recommend?
