Hello all.
I have just stared as welding QA. I have been working as Welder for 11 years ans my first job is to develop PQR for our client. welding must be qualified to ASME IX construction code is B31.3.
client specification is impact testing must be conducted at -60deg C
all material is A790 UNS31803 22%Cr DSS ranging is wall thickness from 3.8mm to 30mm
(impact testing to be in weld metal FL+2)
my question is on the material certificate I noticed that the pipe I have perched to weld coupons for testing has had CVN at -50deg C and the 25mm plate I have perched for weld coupons has only got CVN tested at -46deg C.
1. Will I have to re-test base material to -60. So after welding coupons have the lab do CVN for weld metal, FL+2, FL+5 and base metal?
{b}2. how to I work out the minimum impact values for -60 CVN testing. The client first told me that CVN testing would be -50deg C and i think about 50J/42J (around there) now how do I work out what is minimum impact value in Jules for new temp of -60deg C?{/b}
if I have ISO drawing with design temp rang of -46 to +80 and hydro test pressure of 35000 Kpa using ASME B31.3 how do I work out CVN test temperature and single/average Jules required?
I thank you all for you help in advance...
