Ashayeri
We use a vacuum to presaturate (deair the system and sample) prior to back pressure saturation. Fat clay has never been a problem for us, even though the vacuum is the least effective on a stiff clay. As Focht3 pointed out, filter paper strips have to be used. Many times an overconsolidated clay will not reach a "B" of 0.95. You may notice that the "B" will peak at some point (usually in the 0.85 to 0.9 range) then drop with increasing back pressure. This is also an indication of saturation. We have found that sands are the tough ones, surprisingly. You have to de-air by vacuum, (prevac), prior to back pressure saturation for sands. As an example a sand without prevac, just back pressure saturation, may take well over 100psi to get a good "B". With prevac a sand can be back pressure saturated by 30 to 40psi! You have to be careful not to overconsolidate the sample if you are using confining pressures less than 15 psi.
Best Regards,
David Cooper
Cooper Testing Labs
