13392017
- Dec 15, 2003
- 28
Hello Guys,
I am beginner in designing fluid power applicaton. I need your expertise advice for the problem we have now.
We are designing some electrohydraulic system for spooling cable. The system will equiped with 2 discbrakes for controlling the cable tension, Hydraulic accumulator, one hydraulic motor, one hydraulic pump & 11 kW electric motor as power source.
The system almost finish unless the heat exchangers for cooling system.
I have no idea to size the cooling system.
We planned to make some air cooled HE, with fan installed on shaft of Elect. Motor & Hyd. Pump. And Circular tubing with fin at the outer side of fan. The size of tubing is about 1/2 " ID.
I need some formula to size the diameter of circular tubing and how much circle i should build.
(The power loss which is converted to heat, estimated will be about 25 % of Power Supply (2.75 kW))
