Amelie2004
New member
I am trying to model an axisymmetric model using Patran. I have been using CTRIAX element, and I've drawn the model in the x-z plane, so that the part is rotating around the z-axis. The part is quite simple (similar to an empty tube with an inside pressure) however, when I applied the pressure, without any others bc or contraints, the model does not work. I am using NASTRAN as the solver. Do you have any tips?
