Axisymmetric model in NX 7.5
mobech
11
I'm going to do an analysis on a threaded connection on a pipe. I would first like to make an axisymmetric model of the threaded section of the pipe so that the analysis do not demand that much computer power. Could you guys give me a few tips on how to make an axisymmetric model? I'm using Siemens NX 7.5.
Thanks!
It's easiest if you create the full model of the pipe then cut it in half.
So what do you know about creating models in NX ?
Not sure exactly what YOU mean when you say you'd "like to make an axisymmetric model". Could you provide a bit more detail please?
Note that the 'Scale Body' function in NX does provide an option to perform an 'Axisymmetric' scaling of a model, that is the ability to set a different scale factor along one axis of the model as compared to the rest of the model. There's also a 'General' option which lets you input three different scale factors, one for each axis of a model as defined by a selected CSYS.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The assignment is to do an finite element analysis of a 4.5" ASI threaded pipe. The radius at the bottom of the thread is about 1.5mm, so I need a very fine mesh to do an accurate analysis. So instead of analyzing a 3D model of the whole threaded pipe, I will do an analysis of a 2D axisymmetric model. I would like to know how I can make this 2D model in NX.
There's an excellent video tutorial in NX8.5 help showing the procedure for an axisymmetric structural analysis, do you have similar in NX7.5 ?
Hello!,
Yesterdy I wrote a post regarding 2D Axisymmetric analysis with NX Advanced Simulation, here you are the link:
original
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: Blog de FEMAP & NX Nastran:
Thank you, I'll check it out!
Your post about axisymmetric models explains very good what it is, but I`m finding it difficult to find the functions and how I`m supposed to make the model in NX.
Hello!,
Well, the workflow is very easy and simply:
1. Open the part or assembly.
2. Create the FEM and Simulation.
• Solver = NX NASTRAN
• Analysis Type = Structural
• 2D Solid Option = ZX Plane, Z Axis or XY Plane, X Axis
3. If necessary, position the model so that the axisymmetric portion of the model is on positive half of the axisymmetric plane. Axisymmetric analysis requires that the center of rotation and radial axis of the axisymmetric model be properly aligned to the absolute coordinate system. You can use the Reposition Master command to reposition the idealized part.
For the NX Nastran solver:
• The axisymmetric axis is absolute Z
• The axisymmetric plane is absolute XZ for positive X
This means the model must lie in the +X half of the XZ plane.
4. Make the FEM the work part.
5. Open the idealized environment.
6. Split the body: Use the XZ-plane to split the part in two using Split Body command (Advanced Simulation toolbar, Geometry Preparation Drop-down list)
7. Mesh the axisymmetric faces in the +X half of the XZ plane with 2-D QUAD axisymmetric elements.
8. Define the physical and material properties.
9. Apply loads & boundary conditions, solve and postprocess results.
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
So I'm not supposed to choose "Axisymmetric Structural" under Analysis Type?
Dear mobech,
Axisymmetric analysis is supported in the NX Nastran Structural, Thermal, Axisymmetric Structural, and Axisymmetric Thermal environments, and the NX Multiphysics Thermal environment.
Simply choose Axisymmetric Structural, and you are done.
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
OK, thank you. I think I'm doing it right now, but when I'm trying to see the solution I get a warning message that says: "Result not loaded" and "Result File in wrong format". Any idea why?
Hello!,
This means that the solution gave error. Open the *.F06 (this is the nx nastran output file in ASCII format) located in the same directory as the *.SIM file and look for the word FATAL, there you will have the description of the error.
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
I`m getting these two warnings:
*** 17:39:06 ***
WARNING : Skipping load and constraint set spc(1)
*** 17:39:06 ***
WARNING : Skipping load and constraint set Force(1)
Not sure what I`m doing wrong...
Hello!,
This content never could be part of the *.F06, you are editing the wrong file *.DIAG, make sure you see properly the extension of the files in Windows Explorer and edit the *.F06, OK?.
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
Upload the nastran input deck *.DAT file, if seems that no loading exist:
Code:
 *** USER INFORMATION MESSAGE 5293 (SSG3A)
    FOR DATA BLOCK KLL
    LOAD SEQ. NO.             EPSILON              EXTERNAL WORK      EPSILONS LARGER THAN 0.001 ARE FLAGGED WITH ASTERISKS
                1          0.0000000E+00          0.0000000E+00
 ^^^ USER   WARNING MESSAGE 9142 (SESTATIC)
 ^^^ [b]THE SOLUTION FOR THE RESIDUAL STRUCTURE AND THE APPLIED LOADS FOR THE CURRENT SUBCASE ARE ZERO[/b].
Best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
Hello!,
In fact, not loading exist in the nastran input deck. Simply edit the *.DAT file with a text editor and you can see it:
Code:
$* LOAD AND CONSTRAINT CARDS
$*  NX Load and Constraint: Fixed(2)
SPC            2      19  123456  0.0000
SPC            2      21  123456  0.0000
Make sure you apply loadings EXCLUSIVELY to the edge of the face that you used to mesh with 2-D axisymmetric elements, only loadings in the edge are translated, any load applied to the other geometry will be ignored, causing a WARNING just as the beginning (written in the screen and in the *.DIAG file).
I suggest to ask for CAE training to your NX VAR or RESELLER, the questions you are possing here are very basic.
Good luck and best regards,
Blas.
Blas Molero Hidalgo
Director
IBERISA
