cervantes
- Aug 3, 2006
- 85
just a simple question I think,
fig 9.7 from ASME is more or less the only suitable example for this
generally it was hard for me to find any examples for runout with more than one datum (except fi 9.7) so I just to ask if this is correctly described:
I am measuring runout , but for meaurement process, the pin (yellow) goes thru a bearing, which may tilt a little bit which can deflect the measurement - and I want to reduce that effect
in application, surface B is connected to another surface so this effect is decreased
so in the fact - I shall also specify a datum B (which means that tool for measurement shall change its shape), which means that firstly - I am pushing pin thru bearing till it stops on surface N
am I right?
am I right?
