Information on transient axial hydraulic thrust loading of centrifugal pumps can be found in
1.Fang,K.S.,1978, "Research and Field Study Solve Problems of Upthrust in Vertical Turbine Pumps", Power, Sept. pp.118-119
2.Miyashiro,H.& Takada,K.,1972,"Axial Hydraulic Thrust Caused by Pump Starting", ASME J.Basic Engineering,Sept.pp.629-635 and Dec.pp.947-948
3.Tsukamoto,H.& Ohashi,H.,1982,"Transient Characteristics of a Centrifugal Pump During Starting Period",ASME J.Fluids Engineering, V.104,Mar.pp.6-14
Fang says momentary upthrusts require a shrouded impeller, an empty discharge column allowing the startup to track a low resistance(high flowrate) path to rated flow and a short suction line so weight of rotor assembly can't suppress the upthrust movement.
Miyashiro's tests showed a significant effect of impeller balance hole diameter and location on the flowrate at which axial thrust goes from positive (downthrust) to negative (upthrust)for a 2-stage vertical pump. They agreed with Fang that axial thrust behavior depends on pump specific speed.
Tsukamoto found that head coefficient is very much higher on initial startups than steady-state head providing an impulsive pressure difference across the impeller. A parameter controlling transient chacteristics of the tested pump was Nf*Tna where Nf is final running speed and Tna is nominal acceleration time from standstill to 63.2 percent of final speed.
For centrifugal pumps experiencing many startup cycles during their lifetime, reversed axial hydraulic thrust loading would be or should be a concern for thrust bearing damage that likely applies to horizontal as well as vertically mounted centrifugal pumps. Rolling element thrust bearings would seem to be even more vulnerable to reversed axial thrust than fluid film bearings. What do centrifugal pump manufacturers and or pump users do to evaluate thrust bearing damage potential for reversed thrust loading during startups???
