Hello all,
I'm doing a large deflection analysis with a string of PIPE20 elements. I want a force to work in the pipe's axial direction at any time during the analysis, hence I need a follower force. I know this requires applying an axial pressure since forces in Ansys always point in the same direction.
My question is if there is any way to apply an axial pressure to a pipe element. Maybe there is some possibility by creating a surface at the pipe's end and applying the pressure to that?
Thanks!
Thanks!
