Hi all,
I can only say a little words about pump operating point: if you change the runner speed you change the velocities' triangles at inlet/outlet, and so you can dramatically affect efficiency. This is true especially if the pump runner has fixed-pitch blades: the efficiency curve of such a runner is extremely steep. If the pitch can be regulated/adjusted, then you may calculate the pitch that almost re-establishes the correct velocities in/out triangles (not completely, since the flow deviation depends on the pitch andother factors), and of course you won't be able to guarantee the same head / the same flowrate / the same NPSH, altogether. You can estimate the power required by the pump runner by P=rho*Q*g*H/etai, where:
- rho is water density in kg/m^3
- Q is the flowrate in m^3/s
- g is the earth gravity acceleration in m/s^2
- H is the head in m
- etai is the hydraulic efficiency of the runner.
Then you have to divide by the mechanical efficiency of the pump (bearing losses + ...) and you will find the power required at the gearbox "out" shaft. To find the power required at the motor, further divide by the gearbox's efficiency.
You will rapidly be able to see if the gearbox is rated for the power required. If P(required)>0.9*P(rated) then I personally think your gearbox is at high risk...
Instead of changing the pump's operating parameters, do you have the opportunity to cool down your gearboxes (simple "pipe coil" wrapped around the boxes, taking water from the HP side of the pump, for example)?
