For a CJP procedure qualification/welder qualification test (3/8" thick, 516 Gr. 70, 1/4" steel backing, FCAW, 3G, E71T-1M, 45° included angle) is it expected per AWS D1.1 (or ASME Sec. IX for that matter) that when a welder uses a backing strip they should not need to backgouge as well?
I have not seen anything that implicitly specifies that backing AND backgouge is not allowed, but it is my opinion/understanding that a good welder should be able to get complete fusion into the backing strip without needing to backgouge after.
I understand "The omission, but not inclusion, of backing or backgouging" is an essential variable per Table 4.5 of AWS D1.1 and
Prequalified WPSs in Clause 3 often have a backing strip OR an open root with a backgouge. AWS D1.1 Sec 5.10.1 on Fusion of backing states: "Groove welds made with the use of steel backing shall have the weld metal thoroughly fused with the backing".
It seems some of the guys here have been qualified at the shipyard before where they were allowed to remove the backing and backgouge. Is this just because of a difference in MIL Specs vs ASME or AWS Code or am I just way off base?
Any clarification would be fantastic. Thanks in advance.
Robo
Robo
