AWS D1.1 Joint dimension tolerance 1
sw007
In AWS D1.1, tolerance of the joint dimension is defined in Figure 3.3 and 3.4 by "as detailed" and "fit-up". What is the difference between "as detailed" and Fit-up".
For example: (1) For prequalified WPS, which tolerance I should use?
(2) For WPS qualifed by PQR, which tolerance I should use?
Thanks.
The tolerances are the same for standard joint details regardless of whether the WPS is prequalified or qualified by testing.
The "as-detailed" dimensions are the maximum dimensions allowed on the drawing or instructions describing the joint.
The "as-fit up" dimensions are the maxiumum allowed when measured on the part prior to welding the joint.
See D1.1 section 3.12.3
GRoberts:
Thanks for your reply.
So, for welding procedure qualification, which one should be used, "As-detail" or "As-fit". Based on your interpretation, we should use "As-detail" tolerance because it is drawing.
I would agree with that. That is what I have previously done.
