Skogsgurra
This is not an easy one. I am trying to compile a check-list for VFD installations in domestic buildings. And I am asking for comments on all the issues that come up. Do you have experience or knowledge about these items, then you are very welcome to share with us. Here they are:
1 Mains current distortion: Reactors? Active front end? PFC circuits? Other means?
2 Mains HF pollution: Filter? Isolation transformer? Other means?
3 IT grid and EMC filters: Configuration? Where to connect "ground"? How does the filter affect the insulation level? Other issues?
4 RCDs (earth fault breakers): What setting? Can they be used at all? Getting around nuisance trips.
5 Motor cable reflected waves: Motor reactors? dU/dt filters? Sine filters? Varistors? Other means?
6 Motor insulation problems: Motor reactors? dU/dt filters? Sine filters? Varistors? Extra insulation? Other means?
7 Motor bearing problems: Shaft grounding? Common mode filters? Insulated bearings? Hybrid bearings? Other means?
8 Load bearing problems: Insulated coupling? Equipotential bonding? Shaft grounding? Other means?
9 Bypass switch: Interlock. Shielded cable. Shield connection? Between which units to connect the switch? Other comments to that?
10 Safety switch (to isolate motor when working on it): Interlock. Design for 50/60 Hz or for low (almost DC) frequencies?
11 Derating at higher switching frequencies: Long cables and derating? Long cables and reduced switching frequency? Derating or reducing switching frequency when output filters are used?
12 Any other issue not mentioned here?
To avoid lots of posts recommending the manufacturer's manuals and recommendations, I need to mention that I have studied most of them (ABB, Schneider, Baldor, Siemens, SEW, AB...). I now turn to you, the users, to get some field input and "how to" comments. Your contributions are highly valued.
