automtic mixing systems
HDS
661
Does anyone have recommendations for mixing and dispensing systems for epoxy? I would like something automatic so I don’t have to weigh everything by hand. Who are some good suppliers? What is the best method for preventing the mixed epoxy from hardening in the machine?
Right now I am considering the systems sold by Freeman.
A fixed mixing ratio is O.K. this machine will be dedicated to 1 resin.
TIA
HDS,
Did you ever make a decision on this? I am curious to know if you solved the problem of hardening inside the machine and which system you decided to use.
There are obviously lots of meter-mix systems out there, depending on you material. I've been researching high viscosity 1:1 two part mixers. Any info you could pass along might save me time. One thing I've found is this.
I have not looked at anything besides those machines from Freeman. That system is very expensive but is obviously designed to last a long time and get used constantly. I needed something less expensive.
