Automotive Driveline Geartrain Inertia 2
shiitake86
Automotive
Guys, I'm having trouble calculating the inertia contained in an automotive driveline. This is a simple automotive 'live axle' design where torque is diverted from a single input (differential) to two axles.
Q1. Lets say that the inertia exiting the transmission output is 1 kg-m2, how does this change the inertial of the axle if the final drive ratio is 4.77:1?
Q2. Can I sum the inertia of the two axles together as an approximation? Can I sum the wheel inertia?
Thanks for looking, I've been having trouble figuring this out and I can't really find any resources.
-S
Inertia is reflected by the inverse square of the gear ratio. So your axle inertia is reflected by 1/(4.77)^2
Thank you for your help. Could you explain the difference in reflected inertia based on how you refer the input or output.
Thanks.
-S
In your case, the input is the drive shaft. The reflected inertia is everything rotating on the axle shafts.
