I was wondering what kind of operations you can do with the NXOpen APIs. I am trying to model a non-circular (Oval Shaped) gear. After reading some very thorough documentation on the generation of non-circular gearing it is my understanding that the tooth profile is not consistent throughout the centrode of the gear. I have been trying to come up with the best way to model it and I think I need to simulate the generation of the gear as would be done with a rack type cutter.
I have developed a method to do this manually, however, it will take an extreme amount of time to do and has the possibility to introduce lots of error. I would like to perform these operations using NXOpen and Journaling.
Is this the best way to execute, or is there another way?
Is there a list of the applicable APIs and syntax somewhere in the documentation?
Do I need any other programs to compile the journal into an application (Visual Basic) ?
Thanks for your help.
