S
Sinem Tülek
Guest
Hello, I have a problem that I could not figure out how to solve for a long time..
In CATIA assemblies, if you generate numbering for the product, you can see the "instance number" in the part>properties>product. I hope it is clear so far.
Now, my problem is: in drafting if you use the balloon to number the parts, it should automatically generate the number that assigned in the assembly environment. My computer does not do this. And in complex drawings, it creates a big problem.
I hope someone can find the solution.
Thanks in advance
Thanks in advance
