Automatic Section of the Product
chantzisdim
Aerospace
GB
Dear all
I would like to write a script for exporting sections(1mm step in Z directions) of a product. Can you please provide guidance? I can do it manually but i would like to do it automatically. I can provide the command sequence.
' COPYRIGHT DASSAULT SYSTEMES 2001
Option Explicit
' Purpose : Create a network of sections.
' Assumptions : A CATProduct document should be active.
' Author :
' Languages : VBScript
' Locales : English
' CATIA Level : V5R6
Dim iNumber ' Number of sections in the network
iNumber = 10
Sub CATMain()
' Retrieve the Sections collection
Dim cSections As Sections
Set cSections = CATIA.ActiveDocument.Product.GetTechnologicalObject("Sections")
' Create the master section
Dim oMasterSection As Section
Set oMasterSection = cSections.Add
' Retrieve data on master section
Dim Position(11)
oMasterSection.GetPosition Position
Dim dHeight As Double
dHeight = oMasterSection.Height
Dim dWidth As Double
dWidth = oMasterSection.Width
Dim dMin As Double
If (dWidth > dHeight) Then
dMin = dWeight
Else
dMin = dWidth
End If
' Remove the master section
cSections.Remove oMasterSection
Set oMasterSection = Nothing
' Create the network
Dim oSection As Section
Position(11) = Position(11) - dMin / 2
Dim I As Integer
For I = 1 To iNumber
' Create section and force type
Set oSection = cSections.Add
oSection.Type = catSectionTypePlane
' Modify position
Position(11) = Position(11) + dMin / iNumber
oSection.SetPosition Position
Set oSection = Nothing
Next
Set cSections = Nothing
End Sub
______
Alex ,
Thank you very max alex.
Can you please advise on the following 3 things?
1. Change the sectioning step along the Z axis.
2. Can the macro can always start in absolute co ordinates (xy,zy,xy CATIA Planes)
3. Measure the area of each section and export the number in a txt or csv or....
Thank you very much for your help.
Best Regards,
Dimitris
Code:
Sub CATMain()
Dim oMasterSection As Object 'Section
Dim Position(11)
Dim dMin As Double
dMin = dWeight
Else
dMin = dWidth
End If
Dim oSection As Object 'Section
Position(11) = 1
Do
' Modify position
Position(11) = Position(11) + 1
Indicator = oSection.IsEmpty
If Indicator = 0 Then
cSections.Remove oSection
Else
End If
Loop Until Indicator = 0
End Sub
______
Alex ,
I've got an error on Dim cSections As Sections.
What scripting language are you working in, VBA, catvbs or CATScript? If you are in catvbs, you need to comment out the item types, as Alex has indicated. It will also help if you post what the error actually says.
Just to create the sections...
Code:
Sub CATMain()
Dim cSections
Dim oMasterSection
Dim Position(11)
Dim dHeight
Dim dWidth
Dim dMin
dMin = dWeight
Else
dMin = dWidth
End If
Dim oSection
Position(11) = 0
Do
Else
End If
End Sub
______
Alex ,
 http://files.engineering.com/getfile.aspx?folder=734ce449-5db3-4e07-9642-de2cffe0961f&file=movie.avi
If you are in vbs you cannot use collections...there is no collections class. If you use vba you can use collections...otherwise you will need to use arrays to collect things.
