I'am in charge of designing "Master model" in my company. (Yes, that's soooo coool !)
Most of our product are using the same shape and differ by their dimensions.
So, ideal for 3D parametric modeling.
No issue with the 3D and i'am using the "Visual Editor" to have a user friendly interface to manipulate the expressions.
But the main idea, at the end, is to have less as possible 2D re working.
My model can vary from 150mm to 1200mm.
I manage to have an automatic view scale selection based on expressions using model dimensions and paper dimension, that's fine.
For detail views, i've created rectangles, in the 3D model, in sketches, around the area that need detailing and I'am using it as view boundary. Perfect.
Problem A : I didn't find the way to "lock" detail view in a specific place in the drawing.
Problem B : The dimensions.
They remains well associated to 3D model but their position is a bit caotic when my model evolve from 150mm to 1200mm (yes, that's a BIG step).
So, I've created a sketch in the sheet which contrains only points and edit the dimension's origin so they are associate with a point.
It's ok but if we have to move a dimension, we now have to move a point in the sketch .... where is the gain ..?
With all these automations, my manager is still not satisfied. :-(
And he show me how they manage that in the previous CAD system, PTC Creo.
It this soft, it's possible to create in drafting application a virtual offset line (parametric) from view line that will cary the dimension.
Dimension will be on it but it's still possible to slide it along.
Is there a way to achieve this in NX 8 ?
Thanks guys for ideas.
Stéphane
"My english is bad ? That's why i'am french."
Stéphane
