I have a folder with few hundred of doc files with significant names.
I put also here an excel file as a master-index.
One column from the excel file has hyperlink formula in order to open quickly (no matter what) doc files.
Questions:
- is it a formula that could insert me in other column of the table the data of each doc file (I need to know when was the last update of the files (that means the xls file contains a command to read from a doc file the data of the file)?
- how can I do the following:
(1) mark several rows in the excel file
(2) the corresponding files that have the names in the marked crowd will be copied to other folder?
Thank you,
Questions:
Thank you,
