Automatic 3D Centerline in NX 11.0.2 on Projected view coming out to be longer?
biw01
Automotive
Dec 31, 2011
152
Good Morning to All,
I have been facing a weird issue since the start of the day today. The Automatic 3D Centerline on the Projected view is coming out to be way long as shown in the below images. I checked my customer default settings and I do not find any issues there. I have attached images in the below link. Has someone in this group faced a similar issue?
Thanks,
Amitabh
Are you using a template for the drawing? If so, templates override Customer Defaults and the settings need to be changed in the template file itself.
If only some of the centerlines are longer than others then I'd start looking into how the views were projected and if that checks out then there is something odd going on with your geometry. Also, you may have to adjust the view tolerance a bit if it's getting overly large/high.
Tim Flater
NX Designer
NX 11.0.1.11 MP8
GM GPDL 11-A.3.3
Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
I wonder if there is a conflict here between inches and millimeters
Jerry J.
UGV5-NX11
