Automate Grouping of Sheets...
dgsbsme
I need to be able to print (via VBA on a custom tool button) all sheets in a workbook, EXCEPT the first 2 sheets.
I can make it count the total number of sheets and tried to use:
Dim tabcount As Integer
tabcount = ThisWorkbook.Worksheets.Count
Worksheets(Array(2 - tabcount)).Select
Thinking that Array(2 - tabcount) would be 2 THRU tabcount... not so apparently.
Neither did Array(2 :: tabcount) or Array(2 : tabcount) work.
I'm stuck now. Anyone know how to make it do what I want?
2-tabcount is "2 minus tabcount"
2::tabcount means "2 (here is a new line of VBA code) tabcount"
You can't specify a range of values for the Array function. You have to specify each value. Array will not work for you. You need something like
Code:
Dim Tabcount As Long
Dim myArray() As Variant
Tabcount = ThisWorkbook.Worksheets.Count
ReDim myArray(Tabcount - 3)
For i = 0 To UBound(myArray)
  myArray(i) = i + 3
Next i
Worksheets(myArray).Select
-handleman, CSWP (The new, easy test)
