Autoasm with layout (skeleton) functionality.
  • Thread starter Thread starter hrishi
  • Start date Start date
H
hrishi
Guest
Hi all,
I'm lookoing for something like how to make an assembly driven by parameters & layouts (layout of the skeleton)so that parts (with fam table) can be auto replaced & can be placed automatically where needed by the user (I thk can be driven by parameters, relations,program).
Though above description is not that brief but if somebody gets an idea what I'm looking for ,Please let me know.
& going further deep I would like to konw any possibility like designing a utility with GUI(or whatever u call it)in proe where the user has to select the parts,fill the Specs & proe will create the auto assembly with layouts & skeleton.
Thanks In Advance
Hrishi
Please friend I wanna know in brief, please sombody help me.
Thanx.
Hrishi
Hi hrishi we can do this. Let me know still u didn't find solution. I can explaid with samll example.
regards
PSReddy
GE IBC
Hyderabad
India
Hi Prasad (guessing)
Can you please give me ypur mail ID ? I'll contact you & will tell you in detail.
Hrishi
First you must use advanced replace on the component, and successfully use the layout (family table, or Interchange group). Then go to PROGRAM/EDIT. First enter an input for the variableunder the INPUT header.
parameter=string
/*short description of function
Scroll through the program untill you reach the add statement for the desired component. Replace the component name with the parameter in parenthasis.
add component (parameter)
Save and exit the program. Now when you regenerate it will ask you to specify the parameter. If the value you input matches an interchangeable component it will be replaced. Repeat this for every component you want to replace.
You can also use relations, instead. Here is an example!
INPUT
size=string
/*big or small
end input
relations
if size== big
handle=12345
endif
if size==small
handle=23456
endif
end relations
add part (handle)
